svanlith
Feb 19, 2016Aspirant
R8000 & Readycloud Registration failed
Hi Fora,
I have recently updated my R8000 to firmware version V1.0.3.4_1.1.2 and figured I'd give the Readycloud a try.
So I was able to logon online and even with the app, but as soon as I try to connect my R8000 with the EXACT same username and password (please don't ask me if I'm sure :-) ) it gives me the following error:
Registration failed. Please check your user name and password and try again.
Anybody any ideas what I am doing wrong or what might be going on?
In eager anticipation of your replies
Serge
Hi jeffm6719,
Try changing your password to a simpler password. For example: Password123
- jeffm6719AspirantI see website doesn't list it. But all the setup for readycloud is in setup
- jeffm6719Aspirant
- jeffm6719AspirantYes
- storm1985ProdigyWNDR4300 does NOT support ReadyCLOUD
http://kb.netgear.com/27323/Which-NETGEAR-routers-support-ReadyCLOUD?cid=wmt_netgear_organic - jeff6719AspirantI have a wndr4300 mine just says registration failed but login to website fine
- danntlewisAspirant
I also have the same issue. "Registration failed. Check your user name and password and try again".
- ElaineMNETGEAR Employee Retired
Just want to check with you guys if you're still having problems.
Let us know if you're still having difficulty registering.
- mwallTutor
Yes, just bought a R8000. When trying to use readycloud I just get "Registration failed. Please check your user name and password and try again." So there is still a issue...
svanlith I was able to register it on the admin page. Please try one more time. If the problem persists, try to change your password.
danntlewis Do you have the same model number?
- svanlithAspirant
Hey,
thanks, but unfortunately I still get the same error.
Somebody from Netgear support able to have a looksy please?
Serge
- JennCNETGEAR Employee Retired
Hello Fora,
You have posted this to ReadyNAS board. I will be moving this to the right board which is Home Networking > WiFi Routers > Nighthawk.
