tj66's avatar
tj66
Tutor
Aug 14, 2015
R8000 55 Mbps vs 90 Mbps for direct connet
MY speetest results are routinely 90 Mbps when connected directly to the cable modem.  When I connect the modem to the router, my ethernet sppeds drop to about 55Mbps.  Any ideas?
  • When connected to the R8000, what is the connection speed of the WAN port?
    If you have QoS enabled on the router, disable and test again.
  • I would start by swapping out the Ethernet cable between the router and modem. Try a CAT6 cable..
    • tj66's avatar
      tj66
      Tutor
      Thanks.  I've been using the same CAT5e cable for both tests.  I just switch it from the router to the modem.  I don't happen to have any CAT6 cables.  I'll try to dig one up.
    • tj66's avatar
      tj66
      Tutor
      I ran CAT6 from the modem to the router and from the router to the PC.  No change in speed tests, still 55 from the R8000 and 90 from the modem.
      • netwrks's avatar
        netwrks
        Master
