Alvim
May 21, 2017Aspirant
R8000 Incredible in the beginning, completely disappointing 4 months later
Hello.
I'm about to buy a R8000 however I really resistant due to Amazon reviews. Have Netgear fixed issued.by customer below?
"When I first hooked up this router I was frankly surprised at how well it handled everything I threw at it in terms of connections and constant use. Then 4 short months later I started noticing as some other reviewers have pointed out that the connections would slow to crawl. Suddenly I sporadically started seen my 5GHz connections go from 110Mbps to a consistent .8Mbps (yes thats not a typo, less than 1Mbps). Initially I sent my internet service provider my full ire thinking that there is no way my relatively new router could be the issue. Time warner understandably does not have the best reputation. They came in found no real issues other than old cabling. They replaced all cables even those outside my home going to the power poles on my block. Nothing changed. Sometimes a reboot of both the router would help, other times it did nothing. Sometimes it would be good for a week or several days but it would start working fine eventually. Then I started seeing this issues happen more frequently until finally at the end of December it was an everyday thing. I then noticed that when I swapped out the router with a borrowed one, or when I bypassed it completely and connected directly to my modem I had no issues at all."
Thanks in advance
Joao B Alvim
Thanks in advance
Joao B Alvim
- that makes sense Mike!
from the 1 star reviews I read any of.them had issue resolved.
Anyway..I going to buy r8000 and look for additional warranty
thank you !!!
Would hard to know if that review was fully troubleshot. Issues seen could be mis-cofigurations, ISP service, wireless interferences, cabling, many things. Not all users see issues in the same way.
- AlvimAspirantAll right. I'm still resistant on buying this one. Do you have more 1 year as additional time of warranty? where I can buy 1 year additional warranty period?
I don't think NG offers any additional warranties. You might find additional warranties available from sellers like Amazon or Best Buy or Frys.
You might review the R7800. I have this model. Been a good router since I installed it.
Remember, for every bad review, there are dozens of people who have no problems and never write about it.
Also, the first users don't return to tell you if new firmware has fixed their problems.
When looking at review sites, I try to check the profile. If there are many more ***** reviews than * reviews, I take that into account.
If it is the other way round I run a mile.
In the case of something like this, I would see if people using the same ISP have reported back, on a customer forum, for example.
And check around this forum for comments. Here too you will see mostly problems – that's what this place is for – but do they get fixed?
- AlvimAspirantthat makes sense Mike!
thank you !!!- michaelkenwardGuru - Experienced User
Amazon is a good place to vent about rubbish hardware, even if, like me, you buy as little as possible from those tax dodgers. Reviews there mean that plenty of people get to read the comments, and it might even prod the people who made into action.
I am sometimes amazed, though, by the ignorance of some reviewers. They automatically blame the hardware even though it is obvious that they don't know what they are doing. Fortunately, Amazon allows people to post follow up comments.
- dan_j_Tutor
I have exactly the same opinion about R8000 router. Router needs restart every couple weeks. Maybe the newest firmware will help.
What ISP service do you have? DSL or cable?
What ISP modem Mfr and Model# do you have?
What FW version are you using currnetly?
If you decide to update FW, manually download the FW file. Use IE11 or FF and clear all browser caches before and after loading FW. Factory reset once more after the FW file is processed, then set up from scratch.
dan_j_ wrote:I have exactly the same opinion about R8000 router. Router needs restart every couple weeks. Maybe the newest firmware will help.
- dan_j_Tutor
Hi
My ISP is Comcast, download speeds up to 75 Mbps. I have cable modem, model Motorola SB6121. I installed the newest firmware 1.0.3.46_1.1.32. Meybe will help.
I needed restart router every 3-4 weeks. I have HDD connected to router. I'm sure this is not modem issue it is something wrong with router. After a 3 weeks download/updload speed is decreasing from 20Mb/s to 3-4Mb/s from HDD. HDD is connected by USB 2.0. Also is decreasing speed from internet. Restart helps.
Thank you.
I've recently had issues with this router - bought it back in November 2016. Both 5 GHz bands now get less than 1 Mbps, but the 2.4 GHz band will get around 20-30 Mbps. I can restart the router and the 5 GHz bands will work for a few hours, then drop the speed again. I've tried multiple versions of the firmware with no luck. I also attempted to contact customer support, but since I was past the 90 day customer support, they told me I would have to purchase a premium support package, which is ridiculous since this router cost $260 in the first place.
What is the ISP mode Mfr and model#?
Any other wifi neighbors or electronics near by?
What channels are you using?
Try UpTo 300Mb on 5Ghz.
Try WPA2 and AES only.
Disable IPv6.
