jagdecat's avatar
jagdecat
Follower
Jun 22, 2018
R8000 not providing WiFi. Lights blinking.
Had a power surge which knocked my router out. When it came back there's no WIFI and only lights blinking in sequence from orange to whites at bottom then to all then orange.
Factory reset don't help.
    • antinode's avatar
      antinode
      Guru
      > [...] Here's a reference link to resolve this kind of scenario [...]
         In which there's a link to a particularly old KB article (19841).
      Also, on a Mac, the ping command suggested there will run forever (or
      until manually interrupted, typically by Ctrl/C).  For behavior similar
      to that on Windows, use a command like the following:
            ping -c 4 192.168.1.1
         See also:
            https://community.netgear.com/t5/x/x/m-p/1533866#M87578
      • Blanca_O's avatar
        Blanca_O
        NETGEAR Employee Retired
        Hi jagdecat,
        We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
        Blanca
        Community Team
