theherm's avatar
theherm
ReadyShare vault doesn't recognise USB drive
I've bought a new R7000 and hooked up a Samsung M3 (2TB) USB drive. The router recognises the drive perfectly and works fine for accessing files through e.g. Windows Explorer.
But, Ready Share Vault does not recognise my backup drive and says "No ReadySHARE device detected". I've also tried another Samsung drive (1TB), but it also wasn't recognised. After reading all related posts, I'm unable to get the drive recognised. Please help.
  • Problem solved by de-installing and re-installing the ReadyShare Vault software!
  • No, I only re-installed the Vault software. I think it is necessary to leave the USB drive connected while reinstalling. At least that is how I did it and I think was different from my first installation.
    I had help from the Netgear helpdesk. Maybe try them otherwise. They seemed rather confident in solving the problem.
    • sweller's avatar
      sweller
      Netgear support just told me, "ReadyShare Vault feature is not supported by the C7000 device." and that I should go ahead and return it to the place of purchase. :-\
      Putzing around with the software some more, I stumbled onto the fact that Vault can't get to the USB drive except through Genie. And Genie can't log in without manually entering the IP. For now at least, I have it working.
      • sweller's avatar
        sweller
        Never mind. It failed again. Are you sure yours is till backing up? My most common problem is that Genie doesn't recognize the router.
    • sweller's avatar
      sweller
      Still doesn't work for me. You did a Windows uninstall?
