AbiTex's avatar
AbiTex
Tutor
May 17, 2018
Router conflicting with someone elses
This router has been working fine for about 7 months.  This week it would not allow access to the internet. Suddenlink cable service kept redirecting to verify my account.  The account that it pulls up is not my account- its for sombody on the next block.  Suddenlink sent out a technician- which finally concluded that I must be accessing the internet through the other persons Netgear router- so we renamed the account- accessed it again- same result? Suddenlink doen't understand it? If I turn off the router- the internet connection access goes away- so I can't see how I'm accessing someone elses account- 10 houses down the street.  Yet my internet is now working with another router.  Any ideas?
  • AbiTex's avatar
    AbiTex
    May 18, 2018
    ISP chaged the MAC address. It's working now.
  • > Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
       Is that accurate?
    > [...] Suddenlink cable service [...]
       Is there a modem(+router?) involved?
    > [...] we renamed the account- accessed it again- [...]
       What, exactly, did you change on the router?
    > [...] Suddenlink doen't understand it?
       Someone at Suddenlink might not understand it.
    > street.
       Are you using a wired connection to your router?  That should
    eliminate any chance of your using someone else's router (except by way
    of a Suddenlink problem).
    > [...] my internet is now working with another router.
       Are your LAN IP addresses different with the other router?  (And
    (now) different from those of your neighbor?)
       To me, it sounds as if Suddenlink has some wires crossed (literally
    or figuratively).  I'd re-complain, and ask for a better explanation of
    how, exactly, you could "be accessing the internet through the other
    persons Netgear router".
    • AbiTex's avatar
      AbiTex
      Tutor
      Thanks for your help- I agree.  Yet I reinstalled my old Belkin Router - it works- yet I don't get the speed that the Netgear Router was getting.
      • TheEther's avatar
        TheEther
        Guru
        I wonder if Suddenlink is associating your Netgear's MAC address with this other account? You could try changing your router's MAC address. You should find it under Internet Setup.
