TheTrigger
May 30, 2022Aspirant
Router home page colors
I have an R7000 and when after logging in and the web page loads I am unable to read the information because of the colors. The literally blend in with the background. Kind of funny and exasperating. How can I change the router web page colors?? Thank you for your time and patience.
Your browsers have a dark theme or dark mode enabled? I have this enabled on MS Edge and see this same thing. Disable it fully and the web page returns to normal. edge://flags/#enable-force-dark
Look at the routers web page in FireFox or Opera.
- TheTriggerAspirant
I should mention I'm connecting via my laptop not my cell phone or other android device.
I guess I should also mention I'm using Windows 10.
- KitsapMaster
Another thing you should mention is what web browser are you using?
Do you have any themes installed in the web browser?
This is happening with Edge and Chrome. I was using light theme. Switched to dark theme but looks exactly the same.
I didn't get both web browsers or both themes in my screenshots but you can see what I'm seeing and it doesn't change based on browser or light vs dark theme.
There a screen capture of what you're seeing?
What FW version do you have loaded?
Mine looks fine in MS Edge in Windows 10:
I've got it set to automatically update but it looks like I need to manually update. I'll do that, check the results, then get back with screenshots.
