  • Phone shows WiFi connection. Tried rebooting router, phone and laptop.
    • clithes's avatar
      clithes
      Prodigy
      Are you using an Android phone?  I've seen this before where the phone establishes a connection but you cannot access the internet.
      Go onto wifi settings, select your wifi connection and choose 'forget network'.  Then refresh and try to connect again.  It will ask you for the wifi password again (as you've just deleted it), once you've put this in it usually connects and fixes the problem.
      Hope this helps.
      • tgrstarr's avatar
        tgrstarr
        Phone is iPhone 6s+. I will try when I get home from work. On the router, the one light is orange, where the others are white (see pic). Does this indicate anything?
    • gary57's avatar
      gary57
      ... at least now I do not feel alone ... I just purchased a news Orbi and after working for about five minutes it disconnects with an authorization error ... or something like that ...
      • gary57's avatar
        gary57
        ... at least I did that correctly ... I thi k it may be a firmware download I need ... and you guessed it ... I don't know how ...
