Chief22's avatar
Chief22
Follower
Sep 29, 2025
Router Speed
Download speed from modum is 450 mbps.  Download speed from router is 100 mbps.  Router is a Nighthawk model R7000.  Is this a normal loss in speed or do I need to upgrade my router?  Upload speeds are consistently 40 mbps both direct to modum or through router.
  • FURRYe38's avatar
    Is this with ethernet connected PC or wireless PC?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • CrimpOn's avatar
    CrimpOn
    Sorry to nit pick, but......  How is the download speed from the router being measured?  and... is "100mbps" less than 100 (such as 94mbps) or even 1mb higher than 100?
    When two devices with Ethernet adapters are connected with an Ethernet cable, the electronics built into the physical adaptors negotiate the highest speed that can be supported.  When the link is negotiated as 100mbps, then it is physically impossible to transmit any higher speed than "mid 90's".
    Page 12 of the User Manual describes how the Ethernet LAN ports indicate the connection:
    Unfortunately, it does not appear that the WAN port has a similar capability.
  • StephenB's avatar
    To make CrimpOn​'s hint more explicit: I suggest ruling out the cabling first.  One possibility is that the connection is negotiating fast ethernet for some reason.
    So try a different cable.  If you have spare ethernet switch handy, you could also try putting the switch between the modem and the router, and see if that makes any difference.
