OneJoe2
Jun 13, 2020Tutor
Should the R8000 UI see devices connected via a GS308 switch?
In the supplied user interface, on the Basic tab, "attached devices/wired devices" area, should I be seeing any info at all (like status, IP, MAC address) for devices on a connected GS308v2 or is this area only displaying R8000 physical port connectivity?
Thanks in advance.
- You should see all devices connected to the switch
- microchip8MasterYou should see all devices connected to the switch - OneJoe2TutorThank you! - michaelkenwardGuru - Experienced UserAs long as the switch as after the router.
