Wiineedmore's avatar
Wiineedmore
Solid amber Internet light
Good Morning, I recently purchased and set-up this router, I have a few things plugged via Ethernet cable directly into the router. Yesterday I plugged in a new device and get a solid amber light that never turns white like all the other cables.
According to the manual that means " The router has detected an Ethernet cable connection to the modem" ?  I tried port 1 and 4 but the light remains amber.
  • Thank you, the good news I found the philips Hue bridge communicate with a rate of 100/10 Mbps. But, I couldn't find the info on the other device Samsung smartthings hub however, since they are for the same type of automation stuff I think it's safe to assume it's 100/10Mbps as well.
    Thank you for your help.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Welcome to the community, Wiineedmore
    Amber light means that the device plugged in is only running up to 100Mbps or less.
    The LAN ports of the router are capable of up to 1000Mbps.
    If it's not the device then it could be the Ethernet cable used.
    • Wiineedmore's avatar
      Wiineedmore
      Thank you for the reply ElaineM I changed the Ethernet cables and added an additional device this device gets the same Amber light. The devices are a Smartthings hub and a Philips hue bridge both devices are new.
      • ElaineM's avatar
        ElaineM
        Try to check at the specs of those devices if it's capable of up to 1000Mbps.
