NG27's avatar
NG27
Speeds capped at 100mbps, im supposed to have gigabit R7000 paired with CM1000
i have tried everything i can think of to resolve this issue with no luck. ISP has confirmed GB speeds on the line itself.
  • michaelkenward's avatar
    michaelkenward
    Not a lot to go on there.It is a bad idea to try to cram the whole issue into the subject. There isn't room for a proper explanation.
    You can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    They are there for a good reason.
    • NG27's avatar
      NG27
      copy, well as i stated, my ISP came out and verified speeds on the line, everything checked out on their end. When i turn my modem on, all lights are green as should be but when i turn router on and try to connect my PC via LAN it turns the LAN light on modem amber, which indicates 100mbps. I used to get roughly 850 down and 40 up. My down speed sits around 90 right now.
        michaelkenward
        A smidgen of more detail there but still a bit thin on details.
        The firmware on the router is?
        Can you test the speed out of the modem by connecting to that with a PC?
        The first advice from Netgear's techs would be to reset the router and set it up from scratch.
