guatelize's avatar
guatelize
Stream Smart TV audio to LAN speakers
I have a Samsung Smart TV ue48h6200 & Sony Airplay/Lan/audio Jack Speakers Sony RDP-X700IP (1x) & SA-N310 (2x) and wish to improve audio from my TV to these speakers. Is it possible to connect them all with my the Netgear Nighthawk R7500-100PES X4 AC2350 to stream the audio from my TV to these speakers ?
Thanks for your help.
Best regards
Olivier
  • You should do your own research to confirm the following. It looks like Samsung Smart TV's can send sound over Wi-Fi, but only to Samsung Multiroom compatible speakers. I think you are out of luck with your streaming to Sony speakers. Source: Samsung Smart TV manual.
    Why don't you connect the audio out of the TV to the audio in of the speakers using an audio cable?
    • guatelize's avatar
      guatelize
      Thanks for your reply, I will try your suggestion, but I wanted to avoid the quantity of wires.
      Regards
      Olivier
      • netwrks's avatar
        netwrks
        Master
        There are also bluetooth adapters that can trun wired speaker into bluetooth speakers. If you goolge bluetooth speaker adapters you should be able to find some..
