JohnnyWB
Apr 27, 2016Tutor
Unable to do a fresh set-up wizard install on my Nighthawk AC1750
Ok, I just built a brand new computer, mainly to be used for gaming. My Ether cable runs from the DSL Modem to the Nighthawk Wireless unit, then I ran an Ether Cable directly to my new PC and pllugged it into the MOBO. Now I don't know if it makes a difference or not, I did not buy any type of wireless device to install on my MOBO. I did an install of the Genie App and then the Set-Up Wizard ran but, it left out over half of my selectable settings, when I log into "routerlogin.net". Now, I can't make any changes or do anything so my system is severely crippled. I have uninstalled the Genie App and gone back through my computer and erased all traces of the software and attempted to get the router to re-boot and come up correctly. Well guess what, it came up but I am connected to the internet, somehow, as I using this computer to write this.
Help please.
Johnny
- Retired_MemberApr 28, 2016
If they're greyed out that's a sign you're not in router mode? So the question is what mode is it in? Did you tinker yourself into an unknown mode?
- Retired_Member
You can factory reset the router and the genie app is not required to setup the router
- JohnnyWBTutor
Thanks for your reply but, the Gemie app, is not my problem. Maybe I wasn't clear enough so let me attempt to clarify it. When I log into the "routerlogin/net" so i can set up QOS, tinker with my security settings, and things of that nature I couldn't as nearly half of those features had been grayed out. So after trying to get the set-up wizard to run again and help me re-install the software, I gave up and un-installed the software. I am running bare and have no apparent control over my WIFI device now.
Does that help any?
Thanks
- Retired_Member
