CLAIREWp3's avatar
Sep 09, 2021
update V1.0.5.36
Our router constantly stays on 60GHZ since the update and the router is constantly restarting since the update - nothing shows on the logs so it can only be the update as we had no issues before update  V1.0.5.36.
  • Thank you, the downgrade (down to the previous version) worked last night and had no issues since.
  • plemans's avatar
    Have you tried a factory reset and reinstall?
    Or tried downgrading the firmware?
    • CLAIREWp3's avatar
      CLAIREWp3
      Tutor
      I looked online and could only find V1.1.0.18 - tried installing that and what a mess it really did not like it, gave me constant "trying to configure" window.
      I would prefer not to factory reset
