anirguha's avatar
anirguha
Using WPA3 on Nighthawk R7000 Router
I am using a Netgear Nighthawk R7000 Router for several years now. Does this router support the WPA3 security option for WiFi connection?
I am using the latest firmware available on the router. Just downloaded and upgraded the firmware version to V1.0.11.130_10.2.118 but it didn't help much. The WPA3 option is not even appearing under the security options of wireless set up screen.
Any pointer will be very helpful.
Thanks.
  • No it doesn't.
    You'd have to upgrade to a newer hardware that supports wpa3 if that's what you're wanting.
    Keep in mind, some older devices struggle with wpa3.
  • plemans's avatar
    No it doesn't.
  • anirguha  So you have the answer you sought, but here's a thread from a couple of years back:
    https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-AC1900-has-MFP/td-p/1773101
    Always worth using the search function, especially when asking about the R7000 AC1900, which contains enough threads and repeated questions about the same things. That's not me being in anyway sarcastic, it's just being helpful, that's what the search function is for.
    I've just consigned my R7000 AC1900 to the darkest recess of my attic where it belongs. Replaced it with a TP-Link AX6600 GX90 which does have WPA3.
