StanH
Feb 15, 2017Tutor
With Readyshare Vault, how can I exclude one individual file from backup?
- Feb 22, 2017
Yes - that is correct and a commonly used technique.
Again, just to confirm, I'm responding with regard to ReadyNAS Vault. Can you confirm you are using ReadyNAS Vault (as opposed to ReadySHARE Vault)?
StanH
Feb 21, 2017Tutor
It sounds like I could exclude specific files excluding a folder and by putting the file or files in it. Is that right?
ReadyNAS-Vault
Feb 22, 2017Apprentice
- StephenBFeb 22, 2017Guru - Experienced User
StanH: The answer matters - and you've ignored the question more than once. Please respond. If you are talking about a USB drive connected to a router, you are referring to ReadyShare vault.
- StanHFeb 25, 2017TutorI am using ReadyShare vault. If I were to change to ReadyNAS Vault would the solution be different?
- ReadyNAS-VaultFeb 25, 2017Apprentice
Yes, they are quite different solutions.
While they have similar sounding names and both provide a form of data protection, ReadyNAS Vault is a separate site cloud backup service (also provides desktop applications and mobile apps for backup and access from other devices) and ReadySHARE Vault is a local backup solution to a drive attached to your router.
ReadyNAS Vault has a small free plan and paid subscriptions on top. ReadySHARE Vault is free (except that you have to provide the drive).
A detailed breakdown of the differences can be found here:
