frekin's avatar
frekin
X10 R9000 wired network running at 100Mbps
I recently bought a X10 R9000 router to replace my old WNDR4500 N900 router, also from Netgear. I have Cat 6 or better ethernet cable running from the cable modem to the router and from the router to two computers.
- When the WNDR4500 was installed, I could achieve ~80 - 100 megabytes per second transfer rates between my two wired computers (~gigabit speeds)
- The leds on the old router indicated gigabit ethernet connections
- I installed the R9000 in the same location and did not change any of the ethernet wiring or the gigabit switches I have in place
- The R9000 shows white flashing leds for the two computers, indicating gigabit ethernet connections
- When I transfer a large file, the speed clearly tops out at ~10-11 megabytes per second, like it's hitting a hard limit (looks like ~100Mbps ethernet)
- I disconnected everything and connected both computers directly to the router using Cat6 cables and I still see the same transfer rate limit
- I turned off any QOS settings I could find, but no change
I have already checked for new firmware (none available yet). Do I have a defective R9000? I'm really considering returning this and waiting for a less buggy AC7200 router to come out. At this point, my expensive router looks like a downgrade.
  • Try to reflash the firmware and do a hard reset.
    If it didn't work, I suggest that you exchange it for a new one.
    1. With the unit powered on, press and hold the reset button on the back of unit for 30seconds.
    2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds.
    3. Power on the unit while STILL pushing the reset button and count for another 30 seconds before letting it go.
  • Have you reset the lan cards on the computers to tell them about the new router?
     What color are the lan ports leds white or amber?
    • frekin's avatar
      frekin
      I only reset one of the connected computers, but not the other (mini-ITX server).
      Both of the wired connections showed white leds on the router, so I assumed that they were gigabit. I also tried all of the other ports in various combinations, and the result is always the same.
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
