Luca28
Jul 10, 2022Aspirant
nordvpn hybrid vpn non funziona
buongiorno ho seguito le istruzioni per configurare nordvpn su hybrid vpn ma quando vado ad inserire lo script con annesse credenziali nelle impostazioni avanazate della hybrid vpn non si collega.
vi lascio il registro:
Sun Jul 10 17:29:08 2022 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 24 2022 Sun Jul 10 17:29:08 2022 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Sun Jul 10 17:29:08 2022 WARNING: --ping should normally be used with --ping-restart or --ping-exit Sun Jul 10 17:29:08 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Sun Jul 10 17:29:08 2022 Non-Hex character ('G') found at line 20 in key file '[[INLINE]]' (240/128/256 bytes found/min/max) Sun Jul 10 17:29:08 2022 Exiting due to fatal error
ho parlato con il team nordvpn e sembra essere che il mio xr500 non riesca a leggere tutte le informazioni.
di seguito lascio anche lo script (togliendo le key)
client dev tun proto udp remote 185.153.176.218 1194 resolv-retry infinite remote-random nobind tun-mtu 1500 tun-mtu-extra 32 mssfix 1450 persist-key persist-tun ping 15 ping-restart 0 ping-timer-rem reneg-sec 0 comp-lzo no remote-cert-tls server auth-user-pass verb 3 pull fast-io cipher AES-256-CBC auth SHA512 <ca>
In inglese per favore
- Luca28Aspirant
hello Netduma-Fraser, I followed the instructions to configure nordvpn on hybrid vpn but when I go to insert the script with attached credentials in the advanced settings of the hybrid vpn it does not connect.
I leave you the register:
Sun Jul 10 17:29:08 2022 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH / PKTINFO] [AEAD] built on Jan 24 2022 Sun Jul 10 17:29:08 2022 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Sun Jul 10 17:29:08 2022 WARNING: --ping should normally be used with --ping-restart or --ping-exit Sun Jul 10 17:29:08 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Sun Jul 10 17:29:08 2022 Non-Hex character ('G') found at line 20 in key file '[[INLINE]]' (240/128/256 bytes found / min / max) Sun Jul 10 17:29:08 2022 Exiting due to fatal error
i talked to the nordvpn team and it seems to be my xr500 can't read all the information.
below I also leave the script (removing the key)
- Netduma-FraserNetDuma PartnerCan you try removing the spaces above and below remote-cert please and try again?
- SimonaCaNETGEAR Employee Retired
Salve Luca28,
Benvenuto nella Community NETGEAR Italia 🙂
Di solito non consigliamo di installare software esterni sui dispositivi NETGEAR in quanto possono invalidare la garanzia per i prodotti stessi.
Le suggeriamo di verificare la possibilitĂ di installare NordVPN sul forum NETDUMA.
Relativamente a HybridVPN, potrebbero interessarle la seguente discussione: DumaOS Optimal Settings Guide: Hybrid VPN
Inoltre, come indicato nel link Netduma, Hybrid VPN contiene PureVPN e HideMyAssVPN.
Saluti,
Simona
Team NETGEAR
- Luca28Aspirant
- Luca28Aspirant
I tried to do as you asked me but always the same error.
I report it belowMon Jul 11 14:59:27 2022 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 24 2022 Mon Jul 11 14:59:27 2022 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Mon Jul 11 14:59:27 2022 WARNING: --ping should normally be used with --ping-restart or --ping-exit Mon Jul 11 14:59:27 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Mon Jul 11 14:59:27 2022 Non-Hex character ('G') found at line 20 in key file '[[INLINE]]' (240/128/256 bytes found/min/max) Mon Jul 11 14:59:27 2022 Exiting due to fatal error
