nquintero's avatar
nquintero
Initiate
Oct 01, 2025
BE9300 – 2.4 GHz Band Stops Working While 5 GHz Stays Stable
I’m having an issue with my Nighthawk BE9300 where the 2.4 GHz band stops working while the 5 GHz and wired connections remain stable. Symptoms:
  • Devices on 2.4 GHz drop offline or cannot reconnect until I reboot or disable/re-enable the 2.4 GHz radio.
  • The SSID stays available, you can connect to it but its "offline"
  • Logs show heavy DHCP churn and repeated “DoS Attack: RST Scan” messages from external IPs.
  • Firmware is up to date. It usually gets resolved with power cycling it.
Has anyone else experienced this with the BE9300 (or similar BE-series routers)? Didconfig change fix it? Any tips would be appreciated.
  • FURRYe38's avatar
    What FW version is loaded on the RS router?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Is Protection Engine enabled on the router? If it is present, please disable it.
    Is IPv6 enabled on the router?
    Is Smart Connect enabled on the router?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
  • Thanks for the follow-up, here are the answers to your questions:
    * Firmware: BE9300 running v1.0.1.90 (latest available online)
    * ISP Modem/ONT: AT&T BGW320-505 with IP Passthrough (DHCPS-Fixed) to the BE9300
    * Cable: CAT6A shielded between modem and router
    * Protection Engine: Disabled
    * IPv6: Disabled
    * Smart Connect: Disabled
    * 2.4 GHz: Manual channel 11, 20 MHz width, WPA2-AES
    * 5 GHz: Manual channel 44, WPA2/WPA3 mixed
    Despite this, all 2.4 GHz clients drop offline around 4 a.m. while  SSID stays active. The 5 GHz and wired devices remain connected, and the only recovery is a power cycle.
    At this point, it looks like a firmware-level 2.4 GHz radio hang (same symptoms others have reported on v1.0.1.90). Is a known issue? Would a firmware hotfix or replacement unit be need? This has become a security concern since my cameras and AC units rely on 2.4 GHz connectivity.
Appreciate it
    • FURRYe38's avatar
      What brand and model# are these 2.4Ghz devices.
      Do ALL 2.4Ghz devices go off line at this time frame each day?
      How many 2.4Ghz devices do you have connected?
      Does channel 1 or 6 show same problem?
      Can you test with Smart Connect enabled?
