ilian007
Dec 08, 2025Aspirant
Can I use MS80 Satellite with RS280 router ?
Hello,
I wonder if I can use MS80 Satellite with my RS280 Router ?
I know there is newer MS90 WiFi 7 that is compatible. However, I want to use MS80 is compatible as cheaper option.
Thank you!
No.
MS can only connect to there perpective model MR units:
Nighthawk MK Series MESH System Compatibility Information | NETGEAR Communities
- ilian007Aspirant
Thank you for the quick response to everyone! If you know, can you tell me what do I need to get to extend my RS280 coverage ? I prefer extender with Ethernet cable.
Give a EAX80 series a try. I have one that I connect to my RS600 when I have it online. Works good. Just no 6Ghz on the EAX series.
- ilian007Aspirant
Do you think my phone will disconnect from EAX80 and switch to RS280 when I go to the room where my RS280 is (if EAX still has strong signal) ? Currently, my phone is getting 40-50Mbps (stable) without extender in the farthest room (I am not sure if I want to spend $200 to get it to 600Mbps). Currently, in the room with the RS280 I get 1.1Gbps on the phone. I was looking at this MR/MS devices as more affordable option. Thank you for taking time to respond to my questions.
No.
