Champnet's avatar
Aug 13, 2026
Email logs
New poster so bear with me.
Just upgraded from an old D6400 to a brand new RS300. On the D6400 I could regularly email logs but on the RS300 I can't find the option. All on-line advise says the option to set iu up should be in Avvanced, Security, the next option following Schedule. I don't have that option, I'm now wondering if it 'appears' after setting an option that hasn't yet been set.
Thanks for any advice................
  • How sad.  The only previous conversation in the Forum about emailing logs on RS routers was this one from July:
    RS100 Email Logs | NETGEAR Communities
    Speculation from Community members, but no mention of Netgear providing clarification. That leaves us to wonder. Perhaps:
    • The User Manual is correct.  The feature should exist, but the firmware is faulty.
    • The User Manual is not correct.  The feature has been removed (or was never there).
    • Champnet's avatar
      Champnet
      Tutor
      Thanks for your comments and the link, makes interesting reading.
      The reply from Netgear Support looks automatic so I'll wait for a human response...........
      • FURRYe38's avatar
        So on your RS300, you do not see any email configuration under Advanced tab/Security/Email?
  • Thanks for your reply.
    The box is less than a day old so will contact  Netgear Support in the morning asking your question.
    Will post any replies.
    • Champnet's avatar
      Champnet
      Tutor
      I posted the exact same message to Netgear Support and recieved the following reply :
      "We appreciate the details you have provided regarding your upgrade from the D6400 to the RS300 router.
      However, we are unable to fully understand the concern you have described. Could you please provide additional details about the issue and what you are trying to achieve?"
      In addition the reply continues :
      Additionally, if possible, please share:
      - A screenshot of the page where you are looking for the option.
      - Any screenshot or documentation that references the feature you are trying to access.
      - The current firmware version of your RS300 router.
      Once we receive the requested information and screenshots, we will review the details and assist you further.
      • FURRYe38's avatar
  • FURRYe38's avatar
    I believe NG may have removed that feature from newer generation routers. May not have need used a lot by the population thus NG cut it from being seen in the UI.
    • Champnet's avatar
      Champnet
      Tutor
      That's a shame as I found it useful, thanks for your reply..........
