Gjl1950's avatar
Gjl1950
media server not connection to wired connection
r300 router sees hard drive, my samsung s90d connections to media server when connected wirelessly, but
when I connect my samsung s90d tv to a wired connection the media server does not show on tv.
Am I doing something wrong.
Please advise. Gjl1950
  • StephenB's avatar
    Is this the media server built into the router?
    If not, please give some more details on what the server is and how it is connected to your network.
  • FURRYe38's avatar
    Contact the TV Mfr and ask for help and support regaring the TV connecting with media sources on a home wifi router.
    Might ask about FW updates for the TV as well.
    Check the TVs user manual for information regarding connecting to media sources.
    • StephenB's avatar
      plemans wrote:
      Might just try connecting the hard drive to the tv. Then you don't have to worry about transmitting the data.
      Worth testing.  But whether that is a useful solution depends on where else you might want to play the media.
      Gjl1950​ hasn't responded since the initial post, so it's not clear if this is still a concern or not.
  • StephenB's avatar
    Is the ethernet connected to an RS300 LAN port?
  • In answer to the hard drive connection to the router. It is plugged into the usb on the router so I'm using the routers media server which I can connect wirelessly to my tv. But when I connect to my tv with a
    wired connection through a Lan port, I cannot see the built in media server. I hope this clears things up a little bit. If any more information is needed I will supply as soon as I can.
    Thanks
    Gary L
    • StephenB's avatar
      Have you done anything to make sure the TV is connected to the internet generally when connected with ethernet?
      Also, have you tried a different LAN port on the router?
  • plemans's avatar
    The "media server" built into routers is pretty anemic. The only half-decent one was on the R9000 with built-in Plex.
    I'd try the one on the tv. If it doesn't work with the built-in hard drive, I'd check into picking up something with built-in or optional transcoding. Plus then it'd stream to your other devices decently.
    A cheap N150 pc would do it that you could install plex of jellyfin to. Or even a nvidia shield with plex built in would be a great upgrade. Or even an old pc sitting around
    • StephenB's avatar
      Something is wrong if it works on wifi but not ethernet.
      Personally I use Plex running on a PC myself, but the DLNA server in the router is ok if you don't need transcoding.
      That's not a media server - if Gjl1950​ uses it, then that TV is the only device that can play the content.
  • plemans's avatar
    StephenB​ Even when the OP replied, they didn't add any information to their original post. Tough to help without accurate replies.
    • StephenB's avatar
      Actually they confirmed that they are using the media server in the router, and not something else.  And that the ethernet is connected to a router LAN port.
      Well, I think the place to start is to double-check that the ethernet connection itself is working correctly.
