Nazgand
Feb 17, 2026Aspirant
Router DNS settings do nothing
Being able to set the default DNS for everyone in the house is extremely important.
I set up my router to use Quad9 as the primary DNS; the setting does nothing.
https://on.quad9.net/ says `No, you are NOT using quad9.`
Unfortunately, I am not able to install better firmware, which is at `V1.0.6.16`.
Status: `No new firmware available`
Router type: Netgear Nighthawk BE9200 WiFi 7 Router (RS280)
ADVANCED > Setup > Internet Setup > IPv4
Domain Name Server (DNS) Address
[Selected] Use These DNS Servers
Primary DNS:
9. 9. 9. 9
Secondary DNS:
8. 8. 8. 8
Third DNS:
1. 1. 1. 1
ADVANCED > Setup > Internet Setup > IPv6
IPv6 Domain Name Server (DNS) Address
Primary DNS:
2620:fe:0:0:0:0:0:9
Secondary DNS:
2001:4860:4860:0:0:0:0:8888
The router was not the problem.
`Google Chrome > ⋮ > ⚙ Settings > 🛡 Privacy and security > 🔒 Security > Select DNS provider` needs to be set to `OS default (when available)`.
- NazgandAspirant
`Google Chrome > ⋮ > ⚙ Settings > 🛡 Privacy and security > 🔒 Security > Select DNS provider` needs to be set to `OS default (when available)`.- StephenBGuru - Experienced User
`Google Chrome > ⋮ > ⚙ Settings > 🛡 Privacy and security > 🔒 Security > Select DNS provider` needs to be set to `OS default (when available)`.Agreed. Chrome, FireFox, Safari, and Edge all can be set up to use different DNS from the OS (and therefore not the same as the router DNS config).
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
