Retired_Member's avatar
Retired_Member
Feb 06, 2026
RS600 latest version, 1.0.6.16 IoT network works like a Guest Network
Well, I got all excited about the new IoT network capabilities in 1.0.6.16. I moved a couple of devices to the new IoT network, and they connected to the internet. Then connected my phone to the IoT network. It also connected to the internet but could not connect to the devices. Works no different than a guest network. Then switched everything back and working fine. What a waste of time and emotion.
  • Retired_Member's avatar
    Retired_Member
    I had the IoT set to 2.4G only and WPA2.
      Retired_Member
      Sorry, I'm not familiar with an ICMP (ping). As the WiiM was switching from my main network, the setup reported that it had successfully connected to the IoT. The WiiM device uses Bluetooth during the setup from a factory reset and then requires a WiFi connection for further adjustments. With my phone on the IoT network, was when they could not see each other.
    Retired_Member
    Thanks everyone for the suggestions. During my two days of messing around with trying to make it work, I really did try many, many, and many different combinations and reboots on all the devices that I was working with. The RS600 is a very solid router when used in a basic configuration, and that's where I'm at. Thanks again for your responses.
    • FURRYe38's avatar
      Does the IoT device work with it's app if you put it on the Main WLAN?
      I'll try this on my RS600 to confirm this...been testing a RS700 so figured the basic configuration will work for all RS series router. It should.
        Retired_Member
        Yes. I added my WiiM amp to the 2.4G IoT and then put my iPhone on the IoT network. They would not communicate and the WiiM app was telling me to connect to the same network as the amp. My phone had no problems getting on the internet from the IoT network. I had to do a factory reset to get amp back on the main 2.4G network. Put my iPhone on the main 5G network and no problems.
  • FURRYe38's avatar
    Maybe a IoT app or IoT device issue. The IoT Network feature would be the same across all RS supporting routers. Would not be different. All the same base code.
  • FURRYe38's avatar
    IoT network is working on my RS700. Connected two wireless PCs on it and can connect in between them. If I put one PC on the main LAN via ethernet, still can connect to wireless PC on the IoT Network.
    • coolwifi's avatar
      coolwifi
      Virtuoso
      That's good to know. I have been using a separate 2.4 Ghz SSID and same 5 / 6 Ghz SSID's. I am unable to control my soundbar connected to the 5 Ghz band sometimes, but restarting the device fixes it. I will move it to the IoT network and see.
      • FURRYe38's avatar
        Let us know how it goes. Main WLAN is using Smart Connect here. Manual channesl 11, 48 and 37.
        IoT network is using both 2.4 and 5Ghz with PSK2 set for both.
  • FURRYe38's avatar
    Did you performed a factory reset on the router and setup from scratch after v.16 was loaded to see if the IoT network with your devices and your phone worked while all connected to the IoT network?
    IF the phone and IoT devices were connected on the same network, the phone should have access to these other devices on the IoT network. The IoT network will not block or separate them while on same network.
    Be sure your phone was actually connected to the IoT network.
    Historically both Main WLAN and IoT Networks are on same subnet and are not blocked or isolated from each other as this would cause a blockage to happen between the IoT devices and mobile devices connected on the Main WLAN and supporting IoT apps to fail to connect. NG has intended this design for the IoT and Main WLAN networks to avoid this issue.
    What IoT devices do you have connected on the IoT network?
    Retired_Member
    What I have learn from this experience is that you don't buy a router without reading the manual first. I been looking at Asus routers and they have the features and flexibility on the Guest and IoT networks. Will likely be moving on with the next router unless NG can get their act together.
