hockeynut192's avatar
hockeynut192
Follower
Apr 04, 2026
RS600 not connecting
I have  the same issue will work when hooked up to old router but not directly to modem.  Did Netgear get you a solution?
  • FURRYe38's avatar
    Whats not connecting?
    Did you power off the ISP modem then back ON when you connected the RS router?
    My RS600 is currently online with a CM3000 modem. Working good here.
  • plemans's avatar
    What modem do you have?
    What firmware version are you on?
    What error do you get?
