Rhubbard97's avatar
Rhubbard97
RS700 ethernet port issues
As it says in the description, my ethernet ports are giving me trouble.
I bought this router back in May and it has worked great until recently. Every morning when I turn on my work computer, connected to ethernet, it will not connect to internet regardless of which port I use. The port illuminates and is white, showing a strong internet signal, but my computet shows network connected, no internet.
The wi-fi network has always workes well and never shows issue. Even when the ethernet is causing problems I still get a strong connection across the wi-fi network.
This is not an issue with my work computer, it happens on my personal computer which is also connected to ethernet as well.
If I reboot my router it will allow my ethernet connected devices to connect to the internet, and they will stay connected throughout the day, but I have to do this every single time I power on one of those devices.
I have checked and am using the latest firmware as of 8/8/2024
v1.0.7.86
Any help with this would be greatly appreciated.
