avtella
Nov 03, 2025Prodigy
RS700 pinging Google DND every 4-5 secs on AP Mode
I am currently using my RS700S in AP mode behind a pfSense firewall. I noticed the router is pinging 8.8.8.8 and 8.8.4.4 every 4-5 secs showing up in block alerts, more of nuisance than anything with...
CrimpOn
Nov 03, 2025Guru - Experienced User
Does this ICMP connection pattern persist if the pfSense Firewall does not block it?
Even though the RS700 is in AP mode, was the DNS setting set to Google DNS at some point? (8.8.8.8 & 8.8.4.4)
Nov 05, 2025Guru - Experienced User
Seems to me that the only reasons the AP might care about the internet connection are
- to sync time with NTP
- remote management access via the nighthawk app
So you might check if the NTP port or the time server is also blocked by the firewall.
I don't know what cloud server is used for remote management, and am not seeing any way to disable that in the RS700 manual.
Either way, it's not obvious why the RS700 would try to ping both Google DNS addresses when making connectivity checks. You might try a factory reset, and set things up again.
