Frankss
Aug 24, 2026Guide
There is an issue where hidden networks are automatically enabled in AP mode
I use codex to analyze the source code The firmware uses several overlapping state systems, including the NETGEAR config database, Broadcom NVRAM, temporary files, and hardware partitions. Featur...
HappyCat
Aug 24, 2026Virtuoso
Which specific product is this? (from the label)
- FrankssAug 25, 2026Guide
Based on AI code analysis, RS600, RS700, and RS500 all have this issue, My RS600 has this problem, and other people's RS500s also have this issue.
- StephenBAug 25, 2026Guru - Experienced User
Is this creating an operational problem for you?
The backhaul network is using the same radios as client network, and no one should be able to join it.
It have no noticeable impact in actual use, but whether such an issue is acceptable in a mass-produced product is worth questioning
RS700
https://community.netgear.com/discussions/nighthawk-wifi-7-be/rs700-hidden-default-wifi-ssid/2449760
