Frankss
Aug 24, 2026Guide
There is an issue where hidden networks are automatically enabled in AP mode
I use codex to analyze the source code The firmware uses several overlapping state systems, including the NETGEAR config database, Broadcom NVRAM, temporary files, and hardware partitions. Featur...
Aug 25, 2026Guru - Experienced User
Was believed at some point the NG would introduce MESH features to the RS series. I believe this was side lined and was no longer being worked on.
Are you seeing this hidden network coming from your unit?
- FrankssAug 25, 2026Guide
Yes, it's also a issue with this
- FURRYe38Aug 25, 2026Guru - Experienced User
THe network is locked and not accessible to anyone. Same for Orbi systems. Seen there as well however only used by the wifi system and not accessible to users.
Its possible NG has forgotten to disable it in the RS FW.
Yes, I was so frustrated by this issue so that I used Codex to analyze the source code and find out what was actually causing it
