Frankss
Aug 24, 2026Guide
There is an issue where hidden networks are automatically enabled in AP mode
I use codex to analyze the source code The firmware uses several overlapping state systems, including the NETGEAR config database, Broadcom NVRAM, temporary files, and hardware partitions. Featur...
Frankss
Aug 25, 2026Guide
Yes, it's also a issue with this
Aug 25, 2026Guru - Experienced User
THe network is locked and not accessible to anyone. Same for Orbi systems. Seen there as well however only used by the wifi system and not accessible to users.
Its possible NG has forgotten to disable it in the RS FW.
- FrankssAug 25, 2026Guide
Yes, I was so frustrated by this issue so that I used Codex to analyze the source code and find out what was actually causing it
- StephenBAug 26, 2026Guru - Experienced User
I don't know what source code you analyzed, but even if it is Netgear's open source it won't be complete.
This should be easy for Netgear to fix. But I think it is unlikely that they will make it a priority.
