Ru123
Jan 10, 2025Aspirant
Trouble with Xbox connections
Does the rs300 have full UPnP compatibility?
I have two Xbox ones and cannot use both on online games at the same time. If one’s turned off it’s fine.
All other consoles and devices fine.
I have tried with the default UPnP settings, I have tried port forwarding with UPnP off, I have tried reserving the IP addresses.
From what I can find online if these options don’t work it’s highly likely the router won’t support two Xboxes at once.
Is there a solution that anyone knows of?
might check with xbox and see if having different accounts helps. I know you can't have the same account running at the same time.
Leave uPnP enabled.
Check on the RS web page under Advanced Tab/Setup/WAN setup for NAT Filter. Set NAT filter from Secure to OPEN.
This is needed if you have two more game consoles online at the same time and getting OPEN NAT Staus in games. Found this years ago.
Is there a solution that anyone knows of?- Ru123AspirantThank you both. They’re two different xbox accounts.
I did find that WAN setting and set NAT to open so that’s not it either unfortunately.- FURRYe38Guru - Experienced User
Did you hard power OFF the xboxes and then reboot the RS router after you set NAT Filter to OPEN? After router was bacdk to ready, power ON one xbox and check to see if it's signs on and then check NAT status on it's dash board. Then turn on the 2nd game console?
How are the game consoles connected to the router? Wired is preferred. Can try wireless as well.
