smoothster's avatar
Jul 22, 2025
Unable to upgrade FW stuck on firmware v1.0.7.86
RS700 stuck on firmware v1.0.7.86_2.0.82
My RS700 shows a firmware update available, but the update process goes through and ends up with the original version.
I have even tried a factory reset just taking the default settings to get online and then upgrading and it appears to go through all the steps but ends up on the original firmware.
I have tried manual updates with different browsers
I have been offered
v1.0.7.96
v1.0.9.6
neither firmware upgrade will take. currently always stuck on v1.0.7.86
  • FURRYe38's avatar
    This is a beta unit that we've already troubleshot. I'm hoping that NG can help on this one.
    Seems like the router maybe in some read only or has a fault in the FW partition area that is not allowing new FW to be loaded and processed.
    BH_C​ RichardTTT​
    • smoothster's avatar
      smoothster
      Star
      I successfully upgraded automatically and manually throughout the beta without issue and once after beta.
      • FURRYe38's avatar
        Passed to NG. Someone should be reaching out to you.
      smoothster
      Star
      tried tftp, but don't think I ever successfully got the RS700 into tftp mode
      • RichardTTT's avatar
        RichardTTT
        NETGEAR Expert
        Hi,
        I just PM you a message, can you check it?
        Thanks,
        Richard.
