Retired_Member
May 20, 2021account lock out for zero reason
i am getting account lock outs for zero reason
how do i fully remove this useless feature?
- TheDBugTutor
I think I am getting the same issue as you after I upgraded to the latest software 6.10.5 yesterday. On some browser as soon as I type in the IP address to my NAS I get a prompt to reset password. On another browser (Internet Explorer) I managed to login to my admin page but as soon as it loads I get this Connecting to Readynas Admin Page.... and a prompt to re-enter my username and password and then I get the reset password page.
Sorry I do not have the solution, I have been searching and found your issue and I thought they might be related or the same issue.
- TheDBugTutor
So far I have tried and OS reinstall and at least that let's me log in and do chagnes on my admin page
- TheDBugTutor
So with an OS reinstall resetting the admin password to: `password`, the admin page works. Once I changed the admin password to the one I usually use the problem has returned. So this is definitely and issue with the admin password.
- ajbarnard1977Aspirant
Yep, I am getting the same thing. Now I cant get into manage my ReadyNAS at all. So it sounds like the OS re-install solved it? That doesn't mess with the data on the drives right?
- TheDBugTutor
No the OS reinstall does not mess with your data so you can put your mind at rest. Once I did the OS reinstall and I was able to access the interface normally, via username: admin and password: password. Once you are in download the 6.10.4 firmware from here https://kb.netgear.com/000062588/ReadyNAS-OS-6-Software-Version-6-10-4 and install that. Again no data is affected here.
Follow this thread https://community.netgear.com/t5/New-ReadyNAS-Users-General/Firmware-6-10-5-web-interface-broken-in-final-release/td-p/2093599/page/2
- Apr 16, 2020Retired_Member
