relains
Aug 04, 2016Tutor
Annoying ALT + TAB behavior
Hi, I have a suggestion that to change some functionality in the app, beacause now even when it resides in the tray when I ALT + TAB it shows on the list of active applications. I frequently use thi...
- Aug 04, 2016
Hi relains,
Your idea to improve the quality and functionality of the app is very much appreciated, and we thank you for sharing your interest in this. I also found this behavior a bit odd and hopefully we can make improvements on how the app be properly viewed on PCs. If I were you, I will post another thread at the Idea Exchange board so our development team can review this request.Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Aug 04, 2016NETGEAR Employee Retired
Hi relains,
Kind regards,
BrianL
Aug 05, 2016Guru - Experienced User
Changing this behavior might require re-factoring the windows ReadyCloud client to run part of it as a windows service.
