aroramoney
Oct 13, 2016Aspirant
Auto Back up with deletion
Hi,
- I want to schedule backup daily from a share in NAS to a Remote Drive using cifs option.
- i have done and it is working fine as one way backup except, Deletion from Destination Drive is NOT happening if i delete from Source drive.
- when next Auto sync happens it deosnot deletes from desitnation drive whatever i have deleted from source drive. so, i have to delete manually from source and destination both, pl help. my firmware is 6.5.2 and model Ready NAs 316 and serial no. is 3C67470S00942
- I want to configure one way back up with deletion from destination drive. pl help.
The only way to do what you want with CIFS is to delete the entire destination folder (which is a backup job option) and copy the entire share every time.
You should vote for the enhancement request here: https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/Remove-from-target-on-delete-for-all/idi-p/1153405/jump-to/first-unread-message
You do that by clicking on the up arrow.
- aroramoneyAspirant
Hi stephen,
thanks for reply , actaully total data size is around 3 tb , we cannot delete on daily basis .
is this possible without CIFS ? local NAS to REMOTE HDD one way back up with delete enabled during sync ?
Yes, the option to delete files on the destination that are no longer on the source is available if you use rsync.
Note that leaving a comment in the exchange is not the same as voting for the idea.
- aroramoneyAspirantHi Stephen,
Thanks it's a Windows 7 64 bit system, can you help me with installation procedure doc for rsync server in Windows client and I think then I have to create share In it as well instead of Windows share folder.i hope rsync server is free...- StephenBGuru - Experienced User
There is a freeware implementation of rsync for Windows called DeltaCopy. I haven't used it myself, but other users have reported success with it. You can find a copy here: http://www.aboutmyip.com/AboutMyXApp/DeltaCopy.jsp
