nige_b
Jul 14, 2013Aspirant
Cannot reset ReadyCloud password
Hi, I have just got the ReadyNAS RN102 and installation using the ReadyCloud option worked fine. Later in the day I tried to log in using my ReadyCloud account but I could not log in. I have...
cap1
Jul 17, 2013Aspirant
vandermerwe wrote: Have you registered your readynas?
You should be registered here, and log a support request here, or find the phone number and give them a call.
https://my.netgear.com/registration/login.aspx
You don't need to register your device with support to use readycloud. The support username is different than readycloud for now, we will be merging accounts later this year.
