btaroli's avatar
btaroli
Prodigy
May 25, 2016
Can't activate ReadyCLOUD on my 516 running 6.5
Decided I might try ReadyCLOUD after hearing all the news of change around 6.5. But when I sign in with my MyNetgear login on the NAS, it spins for a bit and simply responds with:   "Unable to join...
  • btaroli's avatar
    btaroli
    May 26, 2016
    Did some searching this evening and found https://community.netgear.com/t5/ReadyCLOUD/NAS-not-on-LAN-in-ReadyCloud/td-p/949253
    Bingo! So, why is it that nowhere in the FAQ or activation step does it mention or warn that UPnP has to be enabled on the NAS itself? It would also be helpful if I didn't have to stumble into the ReadyCLOUD settings on the NAS myself to learn that you have to also set the flag to signify which port to use for incoming connections, for those of us who don't run UPnP on their firewall.
    So far so good. :)
ProSupport for Business
