btaroli
May 25, 2016Prodigy
Can't activate ReadyCLOUD on my 516 running 6.5
Decided I might try ReadyCLOUD after hearing all the news of change around 6.5. But when I sign in with my MyNetgear login on the NAS, it spins for a bit and simply responds with: "Unable to join...
- May 26, 2016
Did some searching this evening and found https://community.netgear.com/t5/ReadyCLOUD/NAS-not-on-LAN-in-ReadyCloud/td-p/949253
Bingo! So, why is it that nowhere in the FAQ or activation step does it mention or warn that UPnP has to be enabled on the NAS itself? It would also be helpful if I didn't have to stumble into the ReadyCLOUD settings on the NAS myself to learn that you have to also set the flag to signify which port to use for incoming connections, for those of us who don't run UPnP on their firewall.
So far so good. :)
btaroli
May 25, 2016Prodigy
Yes it has a static IP. It's been resolving DNS properly for years and has devices I have mapped to it through my firewall. Only the insane enable UPNP on Internet facing devices; so no it is not enabled on my firewall.
btaroli
May 26, 2016Prodigy
So far so good. :)
