horia747
May 01, 2016Aspirant
Can't turn on ReadyCloud
Once again someone else that can't turn on ReadyCloud... Although my serial numbers match unlike people in the other dicussions. I try enabling ReadyCloud on the admin page, it gives me the m...
Newsat11
May 03, 2016Luminary
Will ReadyCloud malfunction with a static IP? I have ReadyCloud enabled now, but I am moving to static IPs for both my device and externally. Is there a known issue?
May 03, 2016Guru - Experienced User
It works with static IPs - mdgm mentions them because it is fairly common for users to make mistakes when configuring them.
But if your router supports address reservation (most do), I suggest using that feature instead of configuing static IPs. That allows you to manage the address assignment from one place, and simplifies migration to new routers (or changing to a different private address range).
