Blue2
May 24, 2016Initiate
Can't upgrade ReadyCloud
Yesterday I upgraded ths OS to 6.5. Among the problems I'm having is that I can't figure out how to upgrade ReadyCloud on my Mac laptop. When I sign in to readycloud.netgear.com it tells me I hav...
kohdee
May 25, 2016NETGEAR Expert
You do NOT want to leave ReadyCLOUD -- that's a bad string that I'm getting fixed. Leaving ReadyCLOUD will remove your ReadyCLOUD private home shares and snapshots.
When you upgrade your ReadyNAS to 6.5.0, it will show your old ReadyCLOUD user until you migrate your account (possibly even a little after).
Once you migrate your old ReadyCLOUD account to a NETGEAR account, your NAS will recieve a signal to change over all the information to your MyNETGEAR e-mail. There will be no data loss.
If your ReadyCLOUD e-mail matches your MyNETGEAR e-mail, you still need to upgrade to migrate your NAS devices.
If you participated in Beta and already migrated from ReadyCLOUD to MyNETGEAR, you do not need to do this again; but you will have to leave ReadyCLOUD beta and rejoin ReadyCLOUD.
AdriFrijters
May 25, 2016Tutor
Hi,
step one works.
step 2 does not work. the screen tells me there is no a registered nas available.
it is also possible to go for 'set up an new nas' but it brings me to the same screen telling ther is not a nas available.
so what is the solution in your answere?
adri.
- kohdeeMay 25, 2016NETGEAR Expert
Step 2 says "Click Sign in" then you get the sign in screen. Is your ReadyCLOUD automatically signing you in because of a password manager? That could be your problem. You don't sign in before migrating your account.
Step 3 takes place in the sign in screen, not after you login.
- AdriFrijtersMay 26, 2016Tutor
Thanks, manual logging out and, after this, manual trying to log in starts the migration. now it works.
Thanks,
