speedliner
Oct 22, 2015Guide
Changed NAS102 to static IP and ReadyCloud reports no registered devices
Hi Folks, This is probably a simple fix, but I can't find a parameter or existing entry to help get me back on track. I recently setup a new RN102 and all was working fine including maped deskto...
speedliner
Oct 22, 2015Guide
Yes, I did set that to the router's address.
Oct 22, 2015Guru - Experienced User
Try checking for a firmware update, and see if it can find the server.
You can also try 8.8.8.8 as the DNS server address, and see fi that resolves it.
- speedlinerOct 23, 2015Guide
I've tried some of the suggestions here. I've removed the static IP for the NAS and reserved an IP address for it in the router. Rebooted both and I can log into the NAS and verify that it has the reserved IP address.
ReadyCloud still can't find it though. I can't find a way to have ReadyCloud reconfigure, or clear a local configuration. No idea where the problem may be. Starting to think I should just return to my Windows Server. This is a PITA. Doesn't seem like it should be so difficult to resolve.
Thanks in advance for any other suggestions.
Rob
- BrendanMOct 23, 2015NETGEAR Expert
Can you click on Check for Updates like StephenB suggested? This is a quick test to verify that the NAS can access the internet.
Checking for updates failed as well. I did solve the issue.
1) I changed the configuration as described above switching back to dynamic IP and creating a reserved IP address in my router.
2) the above did not solve the problem.
the solution:
1) re-installing the operating system.
2) rebooting all devices - router, NAS and PC
3) explicitly logging out of the ReadyCloud desktop client after the reboot and logging back in.
that worked and all is normal again with the reserved IP address. Now my share mapping should survive reboots, etc... Why the above worked I will never know, but lesson learned...
RESERVE an IP address for your NAS F I R S T thing, then proceed with NAS setup and don't install Readycloud clients until your done and all is functioning normally.
thanks for the help folks.
rob
