DaveNetuser's avatar
DaveNetuser
Connecting a newer Readynas unit to a 31400 possible/feasible?
I am running out of room on my RN31400 and want to add some space as well as upgrade this unit. I want to investigate the expansion options. Would it be possible to use this older unit as an expansion box to connect to a newer, upgraded ReadyNAS unit? I am considering purchasing the 5 bay expansion box that's readily available, but I really want to invest in the newer technology of the upgraded unit.
I am currently using 4 WD RE 4 TB drives, and want to keep the 4 TB size as I'm already invested in them, and I don't have a lot of need to expant to larger drives, as the more drives you have, the more versatile it can be with it's functioning abilities. I have 2 more 4 TB Red Pro drives that I use to physically back up the NAS every month, so I don't have to worry about the NAS failure. I was going to use these other 2 drives to add to the collection of drives to make it a 6 drive system. I can buy 2 cheaper units to use as the physical backups, and then expand on that at a later date if need be.
What I'm asking is how to do this. Can I get by without having to use the older unit as a stand alone system? Or can I incorporate a newer unit with an older unit as a dedicated expansion box?
  • StephenB's avatar
    No, that's not possible.
    The EDA500 is one option, though the eSATA connection between the NAS and the EDA can be a performance bottleneck in some situations.  You don't want to create a volume that spans the EDA500 and the RN314 - you'll need two volumes at least.
    Another option is to get an 8 bay NAS (RN528x perhaps), which would give you 4 empty slots.  If you want more storage and prefer smaller drives, then a NAS with more bays is your best approach.
    If you are getting a new NAS anyway, then you will need some more drives too.  So another possibility is that you can mix in some larger sizes.  That lets you increase volume capacity in the RN314 NAS, while continuing to use your 4 TB drives.
    • DaveNetuser's avatar
      DaveNetuser
      Larger drives don't use the full space allocated to the drive unless they are matched with the same or larger drives, is that not correct? I don't want to throw out 4- brand new 4 TB WD Re drives, and I just bought 2 of the 4 TB Red Pro's so I am ready to jump right into a 6 bay NAS straight away. I want to increast the size, but now I am looking at the fact that the NAS I have set up is backing up tself on the NAS, so it's doubling down on the sixe of the storage with the exact same data, and I never intended to set it up that way. I just delested the backups of the data, and it deleted the data in both folders! I have no data now other than the snapshots that can be recovered. I really only need to recover the newest data and get the entire thing redone fresh and stop the redundant backup to itself.
      I need to stop backing up the NAS data to the NAS, if that makes sense, and I'd have plenty of room.
      • StephenB's avatar
        Yes, with XRAID you'd need two larger drives in order to get the full space allocated to the volume.
        I just deleted the backups of the data, and it deleted the data in both folders!
        Something sounds wrong here.  I agree it is not useful to back up a NAS share to the same data volume.
        But deleting the backup shouldn't delete the source.  Can you give us more information the backup job settings?
        Note that if you are accessing the NAS with admin credentials you have two paths to each share.  One is \\nasname\sharename and the other is \\nasname\volumename\sharename.  These are just different ways of navigating to the same folder.
ProSupport for Business
