underroofdog
Jan 26, 2025Aspirant
Corrupted EEPROM for RNDX4420
Hello Everyone I got from my father his old Netgear ReadyNas RNDX4420. A few years prior he tried to upgrade the OS to version 6 and failed, bringing the system into a boot loop. Yesterday I ...
- Jan 26, 2025
Given the circumstances, the most likely cause is that the VPD, which is also in the flash memory, was also corrupted. The VPD is an encrypted file unique to your NAS that tells the OS the unit type and serial number. Without it, the OS thinks you are trying to run on non-Netgear hardware. Only Netgear can create that encrypted file. If you have access to another NVX unit, you can copy the VPD using the method here: Backup-and-restore-of-VPD-file-for-legacy-ReadyNAS-running-OS6 . With Netgear no longer providing support, it won't matter that the serial number will be the same on two units.
Note that this is not "a known side effect of USB recovery". What's known is that when the flash gets messed up, the VPD may be affected, and USB recovery doesn't and can't repair it.
Sandshark
Jan 26, 2025Sensei
- underroofdogJan 27, 2025Aspirant
Hello Sandshark
You are right, my VPD file was missing. Lucky enough, I was able to find a replacement.
Thank you for pointing me the right track.
