ChristianST's avatar
ChristianST
Desktop App changed - PRJNAME
Hello,
after working fine for several month my desktop app on my win 10 pc changed to this:
The Login informaion is not saved anymore, so you have to login manually.
The App is connecting to my NAS - but showing it's "online-Disconnected"
I have checked and reinstalled Java as suggested in a different discussion and I hava de - and reinstalled the desktop app several times.
Connecting via Web Page is working fine; on a different computer there is no problem connecting to my NAS.
Any ideas?
Thanks
Christian
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello ChristianST,
    What's the desktop app version? Have you trued uninstalling it completely and download the latest or of you already have a copy of the latest, redownload it then reinstall?
    • ChristianST's avatar
      ChristianST
      Helle JennC,
      I have downloaded the Version 1.15.1292.517 from http://readycloud.netgear.com/client, so I hope it's the latetst.
      I tried both: Uninstalling and installing by the web installer and manually uninstall and reinstall.
      Same result :-/
      Regards
      Christian
      • JennC's avatar
        JennC
        Hello ChristianST,
        What's your Java version?
        It must have something with the component on the computer that the ReadyCloud app is needed.
ProSupport for Business
