wsirhcm
Aug 06, 2016Aspirant
Device Communication Error at Discovery
I recently had my Nas replaced after 12 months under warranty following what turned out to be an internal a technical issue. I have only recently tried to set up the replacement Nas on my home netwo...
- Aug 31, 2016
Hello wsirhcm,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
dschwartzer
Aug 18, 2016Luminary
Chris:
If I am understanding your posts, it sounds like you are having an issue very similar to one I had. If you know the IP address of your ReadyNAS, I think you can skip the Discover function and just set up the ReadyNAS manually.
Open a browser window and enter 192.168.0.11/admin , which should bring you to the Admin Log-In box. The default IS is admin and the default password is password.
Once you sign in you should be able to set the time zone and change the unit name (if you want to). Click on the Cloud tab and you can then turn on ReadyCloud and enter your MyNetgear credentials.
That should be all you need to do to get the unit up and running and connected to ReadyCloud.
Hope that helps.
David
wsirhcm
Aug 31, 2016Aspirant
David
I am pleased to say that the nas now seems to be working fine.
I did download the latest RAIDar and installed it [as suggested] and have logged back onto ready cloud from there. I am not sure I quite understand why trying to logg onto the admin page via readycloud would not work.
logging in via the ip address seemed to work fine untill the ip address changed without me realising [presumably because i rebooted the nas]. Once I checked the new ip address I could get back in OK but when trying to copy batches of files by drag and drop the copying process kept hanging after a couple of minutes.
I have had two internall pc hard drives start to play up over the past three weeks which was causing windows to run very slowly and this may well have caused some/all of the issues. I disconnected them and windows is now back to running normally. So I can now investigate those issues and hopefully copy the data before they give up completely.
Thanks for all the help. Much appreciated, Chris
- JennCAug 31, 2016NETGEAR Employee Retired
Hello wsirhcm,
