k4heines
Nov 27, 2016Guide
Don't upgrade to ReadyCloud 1.4 if running Mac OS 10.10 Yosemite
Hello, I am writing this to advise others. Don't upgrade to ReadyCloud 1.4 if you're still on Mac OS 10.10. I just upgraded the ReadyCloud client on my Mac from 1.0 to 1.4. Doing this caused ...
JennC
Nov 29, 2016NETGEAR Employee Retired
Hello k4heines,
May I ask what exactly happened after the update of ReadyCloud app? I hope you have also tried uninstalling the app then fresh install the one from download site.
dagmarian
Nov 29, 2016Guide
Hi JennC, the new client app is incompatible with Yosemite. What happens is that a dialogue box comes up and says so; that's it. See attached image.
It's too late to inform us at that point. We want to revert to the old version so we can still use the functionality we had.
- mdgm-ntgrNov 30, 2016NETGEAR Employee Retired
I have passed on your feedback.
btw have you considered updating to El Capitan or Sierra?
- k4heinesNov 30, 2016Guide
Thanks for passing along the feedback.
I've considered upgrading my OS -- I use El Cap on two computers at work. However, I don't want to attempt an upgradde until I fininish migrating a massive photo library from Apple Aperture to Adobe Lightroom. I really don't have a reason to upgrade until that's done. However, I generally do like to be up to date and a fairly early adopter
- JennCNov 30, 2016NETGEAR Employee Retired
Hello k4heines,
Was about to check if that is a bug, thanks to Matt for the feedback.
