hagansbar
Jan 08, 2021Aspirant
Dropbox Sync Not working Continuously shows a Blue Dot
Hi, I am having an issue with my ReadyNAS 102 with the lattest software (6.10.4) and it's syncronisation with Dropbox. Dropbox and the NAS are correctly authenticated and I can list all the direc...
Marc_V
Jan 12, 2021NETGEAR Employee Retired
Welcome to the Community!
The Blue dot means it is syncing, have you checked what files still needs to be synced? Have you added a DNS Server on the Network settings aside from giving it a static IP address?
Have you tried syncing other shares? or to another Dropbox account?
- hagansbarJan 12, 2021Aspirant
Hi Mark_V
There are alot of files that still need to be synced, in the Log that was previously attached you can see errors for the sync.
Yes I have had the DNS set on the Device as 1.1.1.1 & 8.8.8.8 & the Subnet is correct also.
I have also checked the syncing with another account also and it worked but the volume of data would have been lower. I had tried also a couple of different shares setup to sync with theyre own corrisponding folder in dropbox also.
Your help would be gratly appreciated!
Thanks!
