cartermalta's avatar
cartermalta
Failure to log into ReadyCLOUD to enable remote access
Hi all,
I am having an issue when logging into ReadyCloud so as to enable the service for remote access. When I input the (correct) email and password I get the error below, I tried restting my password (if it makes any difference) but the issue persisted;
I made sure that none of the users created clashed with regards to name or email address used and they dont and yet I cannot seem to get it working(image below).
Device: ReadyNAS 104
OS: 6.6.1
Enivronment: 3 person office
I appreciate your assistance
Many thanks in advance
Best regards
  • Retired_Member's avatar
    Retired_Member
    Apr 10, 2017
    Hello cartermalta
    Please check your PM and delete ReadyCLOUD account in SSH,let me know if you can fix the issue,thanks!
    Retired_Member
    Hello cartermalta
    • cartermalta's avatar
      cartermalta
      Hello Deniro,
      I left you a message reply regarding the SSH commands.
      Many thanks and regards.
        Retired_Member
        Issue is resolved,user's NAS configured wrong gateway address so it couldn't communicate with ReadyCLOUD server
ProSupport for Business
