dcheitel's avatar
dcheitel
Firmware update Readynas 102
I am trying to update firmware on my readynas 102. I get the shown error when attempting the update using check for updates function. please advise if able.
Thank you
  • To all that have replied and offered assistance. The issue has been resolved. it had to be resolved by support logging into my NAS remotely and was related to the device not being able to reach the proper repository due to accessability issue on their end. all is good now.
    Thanks again for your kind assistance.
  • StephenB's avatar
    Are you getting the error when you check for the update?
    If so, then manually download the update from https://kb.netgear.com/31116/ReadyNAS-OS-Version-6-5-2
    Then extract the image from the zip file, and use the manual update function on system->settings to install it.
    Or are you getting it when the system applies the update?
    If this is the case, try rebooting the NAS, and then check the firmware version again.
    • dcheitel's avatar
      dcheitel
      actually getting errors both ways. when trying to do the file download and manual install it says unrecognized server error.
      • StephenB's avatar
        Reboot after that, and see if the firmware is applied anyway.
ProSupport for Business
